Old 07-11-2007, 01:07 AM   #2
supramacist
supramacist's Avatar
In the even this doesn't work you can pull the efi fuse and crank the engine to clear the old codes and the use the jumper wire and try codes again.
I know you said you had none but it may be beneficial to clear it and try it again.
