07-05-2007, 12:34 AM
#1
there are lots of possible causes why car won't start: ignition module might be bad; no fuel pressure; injectors are not being fired; toyota starters might gone bad or there's a dirty connection somewhere.. it would be best to check on these things.. anyways, you can look at the service manual, there might be some info on how to bypass the alarm or you could ask the dealer about it.. good luck
