Old 06-24-2007, 11:13 PM   #1
suprabahamut
this happened with my brothers chevy blazer it was the fuel pump if the car gets vibration like shaking the car the fuel pump could get enough vibration to work it and then it cut off like yours did again and the same thing happened but it got to the point where it would not crank with vibration and I had to help buy him a fuel pump for the blazer it was closes to $300 but that is with the fuel sening unit all one assembly. the supras fuel pump I think cost around $80 to $100 its not that bad. try checking first for spark with a spark plug tester they are cheap, and then look at your air filter if its cloged it will not hard start when the engine is hot or really cloged it probly will not start when the engine is hot. if you have spark + air it has to be something with fuel
