Old 06-23-2007, 04:00 AM   #1
supradaddy0803
supradaddy0803's Avatar
for your jumper just do what I do use a little peice of wire from like speaker wire it fits and all you have to do is short it out. In the TSRM the page you want for checking the codes is FI-27 I had to look it up but with a N/A 7m you will be at that page a lot I am afraid. All the other checks I gave you are in there in the sections like IG for ignition and timing is in the EM section for egine mechanical.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
