Old 06-22-2007, 07:11 PM   #5
supradaddy0803
supradaddy0803's Avatar
Lastly to check codes on your ECU take a jumper wire and on the check engine port under the hood bridge the T and E1 ports in it and then get in the car and turn the key on but dont start it. Count the check engine light flashes it will do a series then a space then another series. like a 2 then a 1 for code 21. if there are any on there post them on here and I will tell you what to look at.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
