Thread: turbo question
Old 06-21-2007, 03:38 AM   #1
west_side_supra
west_side_supra's Avatar
well from what i was told the stock manifold isnt very restrictive and can handle loads of boost. so i dont think you need to do anything with that. and if i know this question good enough. i think you would be fine with the stock fuel system being that your only doing 10lbs of boost, but if you want to go higher than that. you'll need HG, Fuel, and air "filter/intercooler/Hard pipes" there is probably more im just not awake enough to tell you it all, plus im not as smart as all these other supra guys
7MGTE - 500hp never dyno'd
fidenza cam gears
