Thread: Head lights
Old 06-19-2007, 12:12 AM   #2
supramacist
supramacist's Avatar
Ya switch the bulbs around for sure. It could be the bulb is mis-marked.
Allighnment is another good one because that will make 1 look more bright than the other one. I am guessing you have one that is noticeabley brighter than the other.
And just plain old crappy wire. Voltmeter time. Check the amperage running into and out of both sets of wires.
Fuse??? I think both of the lights would be out if a fuse was blown but that's just an opinion.
Did you touch the glass of the bulb during install?? If you did it could be trying to go out prematurely if you are running hallogens.
