Old 06-16-2007, 02:10 AM   #1
supradaddy0803
supradaddy0803's Avatar
Ok well that narrows it down a bit ohm out your airflow meter plug when you are looking at it there needs to be continuity between the first 2. After that check your ignition timing and spark plugs. if they are wet then they are not firing. Prolly just timing or a ground off somewhere its them little things that kill you.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
