Old 06-15-2007, 08:45 PM   #1
supradaddy0803
supradaddy0803's Avatar
What I would say to look at is the relay becuase unless you push the little screw in on top of your fuel pressure regulator and it hisses a little then there is no pressure there and it will not start. Check the realy per the TSRM mine says with the big lump up on the pin side on the right is one and then 2 on the left. Then at the bottom 3 on the right and 4 on the left. In the plastic cover thingy on the bottom there is a big lump in one side and the other is smaller dont have pick kinda hard to show but I hope you get it. There should be continuity between pins 1 and 3 and none between 2 and 4 if these dont check out then the TSRM calls the relay bad. Also if you apply voltage between 1 and 3 there should be continuity between 2 and 4. Another way to check to see what it is is to short terminals Fp and +B on the check connector and see if you feel pressure on the fuel line. Check out that stuff and let me know what you find and I will look a little further into it to help you out.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
