Old 06-15-2007, 06:42 AM   #1
88Tsupra
88Tsupra is on a distinguished road
hey man i had that idle problem big time today it went up to 3000rpm and it was idling at 1k earlier
so i pulled over and if you check the throttle cable by the throttle body and if you see a nut on it loosing it up and then take a flat head and loosing the bolt...if i had a picture i would show you. but it works fine it went from 3k to 650 and thats the first time my car has ever gotten to 650 rpm then just take the nut and tighten it up
mines is a turbo so it works you might have a screw on the side of your thorttle body that you can adjust to lower your rpm
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
