Thread: Basic Mods
Old 06-16-2005, 08:26 AM   #1
Guest
Guest
Posts: n/a
If u want more boost simply get rid of that mechanical boost controller and get an electronic one like the apexi avcr.. or just use the good ol' washers on the wastegate trick. Also u wanna make the motor breathe better so aftermarket air filter and cold air intake is a good idea, as well as full turbo back exhaust (or 3" dumpipe and high flow cat as these are often the most restrictive parts of the exhaust). U can get upto about 12 pounds of boost until the fuel cut kicks in, u wanna run more than that on the stock turbo/head gasket?
As for tyres get sum nice wide thin ones.. make sure they're black :P
