Old 06-14-2007, 04:43 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
I've read that running with no thermostat will cause your ECU to run in an open loop, giving incorrect A/F mixtures and ignoring some of the sensors (such as MAF, IAT, etc.) until the car (finally) reaches it's proper operating temperature. This is because the computer thinks it's alot cooler than it is (since the engine takes so long to warm up)... In any case, it's worse for emissions (if that matters) and is very likely to cause premature wear on your engine. I wouldn't recommend it. Found out the hard way that it's bad (destroyed the cold start system on my 92 Jetta)
