Thread: Rear brake pads
Old 06-11-2007, 06:34 PM   #2
supradaddy0803
supradaddy0803's Avatar
If you are jacking up the whole back end and puting it in jack stands then it doesnt really matter seeing as the e brake pads are inside the rear brake rotor. If you are just jacking one side either put the e brake on or chock the front wheels it will roll and you could be under it better safe then sorry.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
