Thread: ect
Old 06-10-2007, 01:05 PM   #1
IHateHacks
IHateHacks's Avatar
Yep. I once had an ECT (not on a supra) read -40 degrees all the time when I checked it with an ohmmeter. That would cause a severe rich condition.
Ok go out to your supra and look at the thermostat housing. You see what the thermostat housing is bolted to with those 2 10mm bolts? Thats the water outlet housing. You see those 2 sensors behind the power steering reservoir? The one on top has a green sensor connector and the body of the sensor itself is green, thats your ECT for the EFI.
Its a dealer only part and will run you around $70.
