Old 06-09-2007, 07:18 PM   #1
supradaddy0803
supradaddy0803's Avatar
You might run into some positioning problems seeing as the SR20 is a lot shorter than the motor that was in it. I am sure it has been done I think the guy that did that V12 in the mark 4 had also done a SR20 in a mark 4 I cant remember. I would look at if you are going to bastardize the car though measurments on the mounts because I am gonna bet you that you will have to make some sort of adapter that carrys the motor further back to sit in the proper position. You would prolly be better off just finding a old 240sx like a early 90s one and dropping it in a lot less work from my standpoint. Pluss the Supra motors like the 7MGTE, 1JZGTE, 1GGTE, and the 2JZGTE are capable of a ton more horsepower and performance than the SR20 you are wanting to put in. Just look at the numbers KWNate is turning with his 7MGTE nuff said.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
