Old 06-09-2007, 06:14 AM   #3
hangsupra
Originally Posted by Fkatz
hey thanks for the reply i've been doing a lot of searchin around on the internet and read that the bolt pattern for the w58 and the r154 are the same, just that the bolt pattern for flywheel is different. i also read that the clutch will fit on the otherflywheel and if i want to use the w58 i have to use the clutch for it not the turbo one. I know that the w58 is weak but i need to use that 300 clutch, i really don't care if the trans blows up in a couple months as long as i fry the clutch so i can feel better about losing 300 dollars. Thanks and do u know anywere i can get a 7mgte motor w/ecu and wire harness or should i finish the rebuild of my bullshit 5mge and turbo it.
first of all.. where you from.. i got couple 7mgte on the yard... due to block head gasket.... and rod, piston problem... if you live close to me... i can sale it for couple hundred... the car have no title... because its junk car...
anyway... i got an 85 mkii 5mge... and i was using the 7mgte turbo setup... and everything is bolt up...
this might be the only problem for you.... because i done it before...
on the 7mgte turbo manifold... you might need to shade little bit... to a smaller side... so it will fit where the power steering pump at... because its little bigger and its not fit perfect... all you do is using some grinder and shade down little bit...
i dont know is it my power-steering pump not in the right spot or ect... because i never replace or remove it.. so i dont know... and thats the only thing or problem i done to make it fit...
other then that... its puzzle time... plug and play...
so far... i only spend $350 on my turbo setup.... hehe...because i got free turbo from my junk yard... hehe...
if you know who need a egr plate blocker... let me know.. i'm make it and i'm selling it... its only... $15.... two piece of egr plate blocker... one piece is at the end of the head where the egr coolant plate at... and one block plate is where the egr valve at... so its two piece for $15 and shipping is only $4...
so if you know anyone intresting let me know alright...
and soon...i got my digit camera i will post up on ebay too... and i will let you guy know about it alright...
