Old 06-14-2005, 04:56 PM   #1
monkihead
SP58GT
monkihead's Avatar
Originally posted by Guest@Jun 14 2005, 08:02 AM
someone tell me why this is:when i start the car white smoke comes out a great deal, smells like anit-freeze. Then my blow off valve has oil leaking out of it, seems to be leaking out of the hoses around there too.
there is no over heating
boost gauge doesnt boost right
no mixtures of oil and coolant when drianed
there is a loose of oil persure
i loose alot of oil over a time limit of about an hour
I have a 89 7mgte auto ct 26 turbo with a bliz blow off valve
was working fine with this set up for a while
i thought it to be the intake gasket can anyone second that?
you may have a bhg or cracked/warped head. as for the oil, it sounds like you have a really bad oil leak if you lose a quart in an hour.
monique- better off dead
