Thread: Over heating.
Old 06-06-2007, 06:27 AM   #1
DavidLeClair584
DavidLeClair584 is on a distinguished road
Way to go and thrash what little confidence I had. Thank you very much. And I have a turbo... This week keeps getting better.
David.
Originally Posted by supramacist
If you need help with a parts list...., you may be in over your head.
In short you replace everything that could possibley ever again give you problems. Upper gasket set. Spark plugs and wires. MHG. ARP. Molly.
Machinist. Starter, you definitley want to replace this while the head is off.
Assorted hoses. Anything that is rubber that has solidified, gets replaced.
Oil and filter. This is just an off the top of the head list, my build list is a bit more detailed.
1.5k isn't going to get it done. The cheapest you can do a BHG on an n/a is right at 2k. 1800ish.
Good Luck.
DavidLeClair584 is offline   Reply With Quote
