Old 06-06-2007, 03:26 AM   #1
mrnickleye
mrnickleye's Avatar
Thumbs up
My AC blows cold but the fan doesn't always blow. The air coming out is always cold but it doesn't blow hard very often, even if I put it manually on High. I can hear the fan turning slowly in the dash. Any thoughts on what the problem is?[/QUOTE]
Sounds like your fan motor brushes are worn out. Works some, sometimes.
You can get an aftermarket blower motor,
CARQUEST/FOUR SEASONS Part #208949 New Blower Motor Without Wheel 86-92 List $63.12 Net $37.88
(you'll pay between net & list)
or pay more from Toyota.
Also check this info out, as it may also be part of the problem.
http://www.toyota-supra.info/forums/...eater+resistor
