Old 05-31-2007, 01:27 PM   #1
supradaddy0803
supradaddy0803's Avatar
There are tons of 1JZ out there for sale with the tranny on them 5spd's are easy to find. As for things you will need if you have a r154 tranny then your driveshaft will work out just fine. The mounts if you have round ones then you are good to go. Square mounts will require adapters our a crossmember swap and beleive me that is a pain. You power steering hoses will not fit right up so you have to modify them. If you want a/c then you will have to have a rear a/c line made to fit. You can extend the harness or you can do like me and KWnate and drill a hole in the firewall under the speedo cable and pass it behind your heater core and turn the ECU around. Other than that the motor fits right in and looks a lot better to me than a 7MGTE personal preference. But if you want ease of swap then go for a 7MGTE pretty much everything will bolt right up and there will be no hard mods. I just wanted the twin turbo and no head gasket problems.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
