Old 05-30-2007, 05:25 PM   #1
supradaddy0803
supradaddy0803's Avatar
I looked in the tsrm and found a tool for that it is in the one listed on this forum not good at linking. As for that I called the toyo house and it is a expensive tool from what they say. If you lived close my friend actually has one he would let you borrow. From what he said you have to replace that nut becuase he thinks it is self locking and has that bent top to lock it. He said it was a 18pt socket that is part of the T handle that it comes on. At least when you do the rebuild you know who did the work and you know that it was done right.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
