Thread: what the hell
Old 05-28-2007, 10:50 PM   #2
west_side_supra
west_side_supra's Avatar
the engine has 160k miles on it, the cam markings on the block that are spose to line up to the markings on the cams dont match up, there cam on the passenger side is lined up with the mark, while the cam on the drivers side is off what looks like 2 degrees, off by a noticable amount, like this much ---
i dont know why, but this would make the valves open at incorrect times. the cam gears are the stock ones not adjustable. and the lug nut thing works fine, its not leaking at all so i dont care, i know they sell the caps at napa i used a bunch of them on my camaro.
7MGTE - 500hp never dyno'd
fidenza cam gears
