Old 05-28-2007, 12:47 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by mav
hi how good are the boost logic turbos..
They work just fine, ime. Boost Logic is a reputable supplier, and has been part of the Mkiv Supra community for several years. I've personally done business with them as well.
and can the na engine take the power ok..
If you get a complete na-t kit from Boost Logic, it will include everything you need to keep the engine safe. A thicker headgasket, and race fuel (or meth injection), of course, will likely be necessary if you plan to run higher boost levels. With the thicker headgasket (depending on turbo size & boost level), and with race fuel/meth (depending on boost level), the engine will handle 700rwhp (6spd) or so, with no problem at all.
has anybody on the forum fitted one or know some one who has mav.
I've used Boost Logic 2jz-gte kits on Turbo Supras before, but I don't usually work on n/a's.
Life begins at 30psi.
