Old 05-28-2007, 04:07 AM   #21
btwilson86
Super Moderator
btwilson86's Avatar
If you remove the inspection plate, it'll show you a portion of the flywheel where it connects to your torque converter. Also, undoing the 2 bolts for the starter and removing it will tell you if you have anything jammed in there, or any evidence of damage on the flywheel teeth and starter gear. However, the removal of the inspection plate for checking the flywheel is really only helpful if you can turn the engine over with a breaker bar... Which we all know you can't at this point.
