Thread: what the hell
Old 05-27-2007, 10:55 PM   #1
west_side_supra
west_side_supra's Avatar
if your are talking about the 3000 pipe to the accordian hose where the bypass valve should have been its not there anymore, the 3000 pipe is now a hard pipe with no holes or brackets, and the part where it would have been hooked up on the accordian hose is blocked off with a lug nut. i have never had a problem with this before.
7MGTE - 500hp never dyno'd
fidenza cam gears
