Thread: what the hell
Old 05-25-2007, 06:21 PM   #2
west_side_supra
west_side_supra's Avatar
hks ssq bov, but the spring is cut and i put in a longer adjustment screw, i have tightened it to the point of where it is impossible for the bov to even open and i still am having that issue, but the point that it is running very very rich is what scares me. is there a way to figure if the 02 sensor is working good. and also my friend said something about the collant temp sensor might have something to do with it running rich. i checked the timing again and it was 2 degrees high but i also didnt short the circute. so that should be very close to being right.
and now i have put 4 clamps for each intercooler pipe because they keep poping apart and also there is a little RTV for each one of them.
7MGTE - 500hp never dyno'd
fidenza cam gears
