Old 05-23-2007, 05:24 AM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Thank you. and also before i get FLAMED dry systems in turbo cars are more harmful than wet i have learned that, so what about a wet system...or should i just build the car and not the bottle. if so what is the next step?thanks for helpin
Supra_87_mk3 is offline   Reply With Quote
