Old 05-21-2007, 05:54 AM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
the head is off and on its way to be decked.if you didn't understand my first post, everything was off but the turbo therfore i couldnt actualy pull the head to do the gasket, bolts were stripped but i did get it off. thanks for your help.
Supra_87_mk3 is offline   Reply With Quote
