Thread: Body Kit
Old 05-21-2007, 05:47 AM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default kit help
hey man. body kits are really strait forward , if it is a good name brand it fits right up otherwise some fiberglassing is needed.. wich is really easy..if you need help ask i'll tell you what i can.
short cuts.... DO not For any resion use wood screws its just stupid ... (the most common method around my area) the correct way to do it is to use the hardware that comes w/ it and maybe some extra brackets you will hafto make..just makes it that much more sturdy...
i cant spell so i just dont try..lol
Supra_87_mk3 is offline   Reply With Quote
