Thread: Tire question?
Old 05-18-2007, 10:51 AM   #11
Sonic
Sonic's Avatar
Sonic is on a distinguished road
Originally Posted by supraman121
well 225/50/r16 225 (the higher the number the wider the tire) is the width 50 (the lower the number the lower the profile) is the height and r16 is the rim size i went to tire rack and looked it up, just went for replacement wheels and the repair manual might tell you..
So mine looks like it should your probably looks more like the tires on my dad tacoma he has 215/55/r14 or something like that taller and skinnyer
ok 225/50 R16
225 is your width yes , its 225 mm wide 50 is your sidewall height (50 % of 225 mm) R stands for radial construction and 16 is your rim diameter .
then there's a lot of smaller letter explaining your load index rating speed and construction date ext ext.
Sonic is offline   Reply With Quote
