Thread: 600whp
Old 05-17-2007, 01:25 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by da_supra_kiid
What do I have to do to get my 97 tt supra from stock to 600whp...
Depends if it's an auto or 6spd. Either way, you'll need to start with a 'full bpu' Mkiv Supra Turbo. You'll need to purchase, properly install, and tune the following: a complete fuel system upgrade, a complete single turbo kit, a fuel computer, a good aftermarket clutch (or built auto tranny), an FMIC, and some wide (11.5") rims (so you don't just sit there and spin with that 600rwhp, or fishtail off the road when boost kicks in).
...how much will this coast me to get my supra to 600whp...
If you do it properly, probably about $15K...
...Which are the best companys for parts.
JUN and HKS, imho.
Like dcrusupra said, you'll need to start with a well-maintained Mkiv Supra Turbo, in very good running order. You should also do compression & leakdown tests on it to ensure the engine is 'healthy' enough to single-turbo.
Of course, be sure to budget enough $ to keep your car properly maintained - a full synthetic oil change costs $50+ and a set of tires can be $1K or more (the z-rated rubber can last as little as 10,000 miles). I'm not sure how long you've had your '97TT, but properly maintaining an Mkiv TT costs like a Ferrari (and not a Celica)...
Life begins at 30psi.
