Thread: Drift project
Old 05-14-2007, 04:28 PM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
well i don't know how new you are to supra's so just some basic stuff to know.
1. you need a mls Head Gasket. w/ ARP Head Studs
also since your drifting you will prolly be using high boost so the MLS head gasket depending on the brand will lower compression from 9-1 to about 8-1 (that is 7m compression) the 1JZ has a 8.5-1 im not sure what it would lower to also
The 1JZ was developed in 1989 to replace Toyota's aging "Truck Engine" the 7M. The 1JZ has a short stroke and high rev limit (7500 rpm). It displaces 2.5 liters the 1JZ-GTE is rated at 280 hp at 8.5 psi of boost. In contrast, the 7M produced 232 hp with 7psi of boost. The C12A turbos have a reputation for failing at high boost (>20psi) in unmodified form. They present the first true limit to the power the engine can produce.
if you would like more info look at this site
http://mkiiisupra.homeip.net/1jz.html
Supra_87_mk3 is offline   Reply With Quote
