Old 05-14-2007, 04:13 PM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
just to updat i cut off the exhaust right after the res. and now the turbo is loose (the bolts were stripped) so my project sjould be almost done.
Supra_87_mk3 is offline   Reply With Quote
