Gee..., it could be any number of things.
You should have cleaned the air intake out before starting and changed the oil and gave it a tune up and new air filter.
You should have pulled the cam covers and checked the head bolts. It will need all kinds of new parts after and if you get it running.
Any auto can not just sit around for a decade without someone knowing they are going to have to rebuild it before driving it.
If for no other reason than when you get it running..., it'll probably start leaking oil in many places.
I would not spend another dime on it as it sits. You have plenty of work to do before you even call a parts store. If it's a manual tranny, you may get lucky and the transmission hold up for a while. If it's automatic.....
Well, Good Luck for sure.
Get a TSRM and a new metric socket set. Especially a 14mm and a 12mm.
Join 3 more forums, and learn anything and everything you can.
EDIT: Have you checked for codes??? If not..., DO.
