Old 05-02-2007, 08:15 PM   #1
west_side_supra
west_side_supra's Avatar
that rubber thing just makes it so the wires cant be touched by water and all of, you can pull that thing off but be carefull its old and will most likely crack and break, you really dont need it but if you can save it use it. if i remember right the plug on the back of the foglights are in there pretty tight so small hands also are needed.
7MGTE - 500hp never dyno'd
fidenza cam gears
