Old 05-02-2007, 01:32 AM   #1
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
ALright, so next Ill check the MAF. Ill check on ebay for a new one.
Guess tommorow Ill break out the multimeter and start checking the MAF, igniter, coil packs and anything else I can find.
I sprayed it down with greased lighting and then sprayed it off with a water hose.
I do own a tsrm. Any other suggestions?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
