Thread: Car Wont Start
Old 05-02-2007, 12:39 AM   #10
j3pz
im having the same problem with mine. got 12v to the coils, coil resistances arent quite in spec but are all consistant (too much of a coincidence that all three are bad, also found someone on supramania with similar problem and ruled it out), cps resistances with in spec. the only things i couldnt do were the secondary test for the coils and the second test for the ignitor assembly.
ive taken my wire and plug all the way to the battery to ground it and still no spark. if you figure it out, lemme know
