Ok fixed the TB from leaking and changed out the fuel filter and its still doing the same thing. It revs, spits sputters, backfires and want go anywhere. Ive checked every plug and connector on the car for moisture and all are clean and dry. Timing is right at 11-12* idling. Ive pulled the timing cover to verify the cam sprockets and crank line up with each other and they do. the crank mark will be on 0 and both cam sprocket marks are with the mark on the backing plate. Still throwing the 31 code for the maf but thats it. All the rest are gone. Im at a dead end with this car. I dont know what else to try anyboy have and suggestion?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
