Old 05-01-2007, 05:14 AM   #2
mrnickleye
mrnickleye's Avatar
Post anywhere that fits your car and need, but not in the FAQs section.
Did the pedal work fine, and then one day it just went to the floor and would not return up ??
That situation won't just be air in the line. Do you see any fluid coming from the slave cyl (area)?
If so, you may have a leak in it. If no fluid on the ground, then perhaps the master cylinder internal seal went bad.
