Worked on the supra for a bit this afternoon and found that the TB is sucking air. Its right between the intake and the TB. I pulled it off and plan on putting a new gasket tommorrow. If only this is going to be my problem.
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
