Old 04-30-2007, 04:27 PM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default hose
autozone sells vacuum hose like the blue kit shown above for 15.00 like he said it is cheap and you do hafto cut but if you take one hose off at a time its not hard.. also you might want to zip tie the ends so they dont slide off.
Supra_87_mk3 is offline
