Old 04-30-2007, 01:31 PM   #10
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
Originally Posted by IHateHacks
Listen to what the ecu is telling you, your MAF is malfunctioning. You can test it with a multimeter, but if its throwing a code and its running like that, its a safe bet that's the problem. Plus the IAT sensor is an integral part of the MAF.
I thought about that, but then again its thrown that code since the day Ive started the car and it ran fine all day until I washed under the hood. What kind of voltage should I be seeing so I can test it today?
Only other thing I can think of is a clogged cat..
I know the cat is clogged, I had planned on putting it on the lift sunday to pull it and knock it out. But I couldnt ever get it to run right to make it to my shop. You can hear it stopped up. It sounds like a leak in the cat.
You said you have 2 turbo supras, so swap out the MAF.
Tried that also, the other car is missing the hole airbox pipe, so there is no maf there.
Did you set base ignition timing to 10 degrees BTDC? Do you know how to disable the electronic advance to be able to set base ignition timing? If not, just ask I'd be more than happy to assist you.
Correct the timing is set. Aligned all marks TDC then adjusted the CPS to 11* while jumping the two terminals T & E.
Slight knock under load eh? *Cough* rod bearings....*Cough*
Oh lord, its a faint knock. Oil pressure looks good but its defiantly a possibility after seeing all the water Ive drained out of this thing. Looks like Ill be pulling the motor from the donor car and start building it up. Until the day the other dies.
Kinda starting to regret buying these cars. Seems like its always going to be something.
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
