Old 04-29-2007, 08:47 PM   #2
mrnickleye
mrnickleye's Avatar
Originally Posted by supramacist
Actually I read last night, the tsrm states 58lbs. of torque.
I used a 2 inch extention and went to 85lbs. myself because I figure the extention threw it off a few lbs.
Did you mean an extension, like a typical socket one (the kind in everybodys toolbox), or like a crowsfoot one??
http://www.engineersedge.com/manufac...e_wrench_1.htm
http://www.engineersedge.com/manufac...e_wrench_2.htm
A typical extension will use the SAME torque spec, because you are still coming straight up in line with the fastener.
You could use any length of this type, 2,3,6,12" etc.
Also, were you using factory bolts? And if so, they are NOT to be re-used.
