Old 04-28-2007, 03:20 AM   #12
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
Ok, everything is complete and put back together. Tried to start it up and nothing. It will just turn over. Im assuming the timing isnt right. The battery is also weak to so that could be some of the problem. Also there is a vacuum line or fresh air tube thats on the bottom of the piping right behind the air filter that I cant find where it goes. Its about 12in long and pre bent so it doesnt go far.
Any thoughts on what to try to get it to start?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
