Thread: code 14 and 52
Old 04-27-2007, 07:57 AM   #22
west_side_supra
west_side_supra's Avatar
ok so i checked the timing made shur to short the circut t and e1 and rpms where at 600-650, the cams lined up with the marks and the pully read 10.
changed the fuel filter <that was pretty cloged up.
and drove it around and noticed the rpms where still hopping around and even got it recorded
RPM jump
so i checked the connector on the CPS and when i touched it the car shut off. so i started it up again, idled fine touched it again and it started clunking to its death, so i started to pull of the old electrical tape. didnt see anything started the car up again, touched the wires and it didnt do anything at all. then i drove it, still running like shit.
so what you guys thinking?
and what is this valve?
7MGTE - 500hp never dyno'd
fidenza cam gears
