Old 04-25-2007, 04:53 PM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
i agree if you cant swap this engine or tranny it is a wast of your money and time when i got my first supra i thought i would have someone fix it and no1 would touch it (blown head gasket) finally i started on my own and it was a learning experiance. it took me 2 times to get it right b/c vacuum lines were misplaced but i tore it down and fixed it w/ me, a friend and a Vehical mat manual
Supra_87_mk3 is offline   Reply With Quote
