Old 04-24-2007, 09:35 PM   #5
dannydavi
dannydavi's Avatar
Originally Posted by cars4me89
same problem you did with the misfire, turned out to be the 6th cylinder plug wire was closing onto the plug all the way. To fix it, I just took some long needle nose and clamped the inside together
was or was not closing onto the plug all the way? if you clamped them together to resolve the issue, i'll assume you meant was not closing onto plug all the way, and in that case i will def check that as well when i install my NGK wires. Make sure they grasp the plug nice and snug.
As for the RTV gasket goo, do you guys put that on the uppper intake to throttle body?
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
