Old 04-20-2007, 04:55 PM   #1
supradaddy0803
supradaddy0803's Avatar
About the struts I have the illumina 2's on mine you dont need TEMS to use them just adjust them manuely. But anyways they are great little stiff but I like my ride like that. They also look good with the eibachs. As for the clunking noise mine did that and it was the tie rod ends the right side was borke I replaced it went away. Easy way to check it remove it from the spindle and move it around if it is broke you will feel cracking inside of it they are pretty cheap. They were prolly broke and when he did the alignment it got worse.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
