Thread: My other car!
Old 04-20-2007, 01:18 PM   #14
kwnate
SP58GT
Originally Posted by 88Tsupra
hey kwante when you said Clip do u mean front clip and if you did is it necessary to get a front clip or can i just get new motor mounts..just tryna get info i plan on doing a motor swap cuz my 7m is acting weird..thanx
wanted to add where did u buy the motor..im really interested in the 1jz swap because its way cheaper then a 2jz
I got the motor locally, you'll need motor mount adapters from BIC performance. The reason you want the front clip is because it comes with the harness, ecu, IC and piping and everything else you'll need to just swap over.
Nate
