Thread: HP Upgrade time
Old 04-19-2007, 03:30 PM   #15
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default thank you
i have a t3 used on a thunderbird i could use if needed it should bolt up. and i was looking into injecters when i got the FP... so i should not boost 15 yet.. i should do 10 and wait until i do a bigger turbo. sounds good. as for HPF dave is the best person i talked to as of now. chris was a lil slower on supras but i still got really good service. spending 600.00 i better. now im just waiting for all the parts to arive and i will back on the road.
Supra_87_mk3 is offline   Reply With Quote
